1999 chevy 1/2 ton silverado Z71 4x4 LS
Old Apr 19, 2011 | 3:59 PM
Clay2026's Avatar
Default 1999 chevy 1/2 ton silverado Z71 4x4 LS
No heat from heater, any tips on air blend door location or any other things to check... Help Please! Its still Winter in Wyoming!!! Thank You
Old Apr 19, 2011 | 9:44 PM
tinbender59's Avatar
More info is needed, does it heat at all, and just can't switch from the floor to defrost???? there are two servo motors on the driver side of the heater unit, under the dash. and each of them have a spring loaded linkage. inspect both of these to see that they are ok. P.S
Old Apr 20, 2011 | 7:16 AM
country_09's Avatar
I had the same problem...all I did was flush out my heater core and now it gets hotter than it ever has
Old Apr 20, 2011 | 11:58 AM
Clay2026's Avatar
Default No Heat
All functions work, floor thru defrost just fine so the problem is somewhere else! Thanks for Your Help!!!
Old Apr 20, 2011 | 12:05 PM
Clay2026's Avatar
Thanks for the help, I'll flush the system and heater core!
Old Apr 21, 2011 | 3:19 AM
Clay2026's Avatar
Flushed Heater Core and Problem Solved! Thanks for All...
silver_fox_19642000
Nov 14, 2014 9:10 AM
89silverado283
Feb 16, 2010 8:50 AM
nycac
Sep 16, 2009 5:02 PM
montana chevy guy
Aug 14, 2009 2:41 AM
