2000 Silverado 1500 Issues
Hey all, my first post her but I'm getting desperate for some help. Off and on for the past couple of years I've run into an issue where my truck would just cut out. Felt like it wasn't getting gas and totally die. It's really hard to explain exactly what it was up to. I started with the easy stuff so I tested the battery and it wasn't where it needed to be so I changed it out. Solved the problem but just temporarily. About six months later the same issue started to happen again but more frequently. It usually happened after the truck sat overnight and sat parked. Once it got more serious it would happen as I was driving. Just shut cut out, stall, surge , rpms up and down and then die. Had a mechanic test my fuel pump and it was bad so I changed it. Solved it all. Temporarily. Check engine light came on and that threw a MAF code and a knock sensor. Changed the MAF and not the knocks and a couple weeks later the light went off before I had the chance to change them. Truck was continuing to run well after the fuel pump change and MAF. We're now three months later and just yesterday my truck very slightly surged while trying to accelerate from a light and then kicked back to where it needed to be. Then today, I parked in the driveway and not the garage and so my trucks nose was uphill. I went to pull it in after being parked there for ten hours and I turned it over and it started very rough, sounded like it wasn't getting gas, surged and died. Second the. It worked, ran a little rough but ran and then worked itself out. Got out and the exhaust smelled a little rich and stronger than usual. What is happening!!?? I can't seem to figure this out.
czombie
Nov 15, 2017 2:24 PM
sniper7
Mar 3, 2012 10:36 AM
