2001 Silverado exhaust
Old Jan 30, 2012 | 9:30 PM
Bscholz's Avatar
Default 2001 Silverado exhaust
Hey I have a 2001 chevy silverado 1500. I was looking into putting a new exhaust on it and was wondering what your opinions are. I looked at cherry bomb glass packs and they looked pretty good. Or there is the flowmasters. I was just wondering your opinions and what some good exhasuts are that sound good. the Cherry bomb extreme looks like you can fake duel it that way, but I dont know if it would sound good. Thanks for the help! Brian
Old Jan 30, 2012 | 9:44 PM
Cpb200's Avatar
well by these mentioned sounds like you want it loud my opinions is a straight threw design muffler magnaflow makes glasspacks which is probably what im going to put on my truck they sound way different then ordinary glasspacks
other recomendations
12 inch dynomax bullet
round magnaflow muffler muffler 14x4
oval magnaflow 11 inch
dont go with flowmasters they have a restrictive design and root out fast
also if you want dual pipes you can get a single in single out muffler and run a y pipe behind the muffler or run true duals but use a x or h pipe with true duals
Old Jan 30, 2012 | 10:12 PM
Bscholz's Avatar
Ok thanks for the reply. Do you know if magnaflow packs sound like cherry bomb packs. I like my pickup to be different than the normal. I guess any glass pack would float my boat but it's nice to get a good one that sounds nice. And is it best to weld the new exhaust in or just clam it?
Old Jan 31, 2012 | 6:59 AM
country_09's Avatar
Weld it for sure, just make sure you've for a good welder or good exhaust shop
Old Jan 31, 2012 | 2:07 PM
Cpb200's Avatar
well magnaflow glasspacks are completely different because
1. most glasspacks have louvers the magnaflow one is perferated like a bullet
2. glasspacks use fiberglass packing magnaflow uses a different kind
3. glasspack come in different sizes magnaflow comes in many sizes but not many options on the length of them
they wouldnt be loud or raspy like normal ones either just a smooth tone
heres some links to youtube vids of them
Magnaflow glasspack 5.3L 1500 - YouTube
2004 chevy silverado v8 with magnaflow glasspack - YouTube
Old Jan 31, 2012 | 8:14 PM
Bscholz's Avatar
I'm not Sure weather I want magnaflow or cherry bomb. How does the loudness comPair between the two. Do they both make the crackle noise. I was kinda leaning toward the cherry bomb extreme with the single to duel. I'm assuming you leave the cat on, what happens if you take it off? Thanks for the replies it helps a lot.
Old Feb 1, 2012 | 7:55 AM
Cpb200's Avatar
cherry bomb will be louder and have more pope and crackle as far as glasspacks go if you went with the extreme then it would be loud even with the cat in if you take the cat out yes you will have more flow but will also be more louder and pop and crackle more
Old Feb 1, 2012 | 9:07 AM
Bscholz's Avatar
Imay have changed my mind to just go with true duel exhaust. I was thinking of putting cheery bombs on there. Should I take the two cats off, or should I just hook up the two pipes after the two cats and before the collector?
Old Feb 1, 2012 | 7:37 PM
JK23112's Avatar
Don't get caught taking the cats off - especially if you live in a state that has a very tough annual inspection process!
wesott11
Dec 1, 2007 9:07 PM
P Rob
Apr 3, 2007 5:11 PM
chevvy2000
Oct 11, 2006 2:39 PM
dan1984
Jul 17, 2006 5:56 PM
