2001 V-6 Slow Cranking , Will Not Start ???
Old Feb 3, 2010 | 8:01 PM
Chevrolet Pete's Avatar
Default 2001 V-6 Slow Cranking , Will Not Start ???
Battery Good , Cranks Slow , wants to cough through the Throttle Body , did this for a few days then started , seemed to Run Fine , now will Not Start , puff of smoke came out twice in back of the air filter to throttle body plastic cover , did not smell like electrical , symptoms to me it slipped time , maybe A fuel pressure regulator and Engine could be hydraulic-ing what do you think , thanks for any input and thanks for the use of this Forum.
Old Feb 4, 2010 | 5:13 PM
Any suggestions will be greatly appreciated , thanks.
Old Feb 4, 2010 | 9:23 PM
MDTAHOE's Avatar
Professional Mechanic
Low fuel pressure, weak spark or a flooded engine (from another problem) is the most likely cause. Jumped timing is possible but not nearly as likely.
Old Feb 5, 2010 | 3:23 PM
Thanks for the Info. Since it Cranks slow could it be a bad ground on the battery cables?
Old Feb 8, 2010 | 7:47 PM
I checked the Battery Cables today , at the battery and both connections at the starter and the ground , everything is clean , could the starter be bad? the starter engages the flywheel and the Engine turns over just slow , what other things can I check? thanks.
Old Feb 8, 2010 | 8:33 PM
maxxman04's Avatar
it is possible that start is bad, drawing way too much power, not leaving enough for the computer to sense/read everything. you had battery tested?
Old Feb 9, 2010 | 2:36 AM
Yes the Battery is good , even Installed new one , I guess I will remove the starter and have it checked or buy a new one , any other suggestions.
Geoffrey Dell
Jul 13, 2011 1:00 PM
rgnbull1227
Feb 5, 2010 2:24 PM
silver911rdb
Nov 26, 2009 8:06 PM
