2003 Siverado Z71 4 x 4 Dash Switch
Old Dec 22, 2008 | 8:42 AM
vBruce's Avatar
Default 2003 Siverado Z71 4 x 4 Dash Switch
I have replaced this switch once because of issues with (from what I was told) bad solder joints. It will drop the truck in neutral on it own at times or its hard to get back into 2wd. I am on my second switch and was told once that they go bad and its a poor design.
Anybody have the same issues and is there a better solution than $60 GM part?
I avoid using 4wd because of this but its not fair! I like to off road....
Old Dec 23, 2008 | 8:23 PM
ukrkoz's Avatar
Default RE: 2003 Siverado Z71 4 x 4 Dash Switch
you did not tell us how many miles you got on the 2nd switch.
yes, they are infamous for being poorly made, but it should not be dropping your transfer case into neutral all by itself. to put t-case into neutral is the whole procedure, with several buttons to be pressed and such. i think, there's an actuator control on the t-case, that might be the culprit. and yes, esp now, around ice and snow - kick him into that AUTO 4WD, and it plowes like a tank through anything! got to have it fixed!
Old Dec 24, 2008 | 6:25 AM
vBruce's Avatar
I have 90K on the truck and had about 65K on it when I replaced it the first time. Is there a way to test actuator? Thanks in advance for your help!!
Old Jan 7, 2009 | 8:58 PM
Sooner69's Avatar
I had the same issue on my 03. it turned out to be the transfer case encoder shift motor. the dealer replaced it for $300 including parts.
Kevino1402
Jul 25, 2014 9:09 PM
robmac69
Aug 13, 2012 7:16 PM
200 combo
Apr 5, 2010 10:28 PM
rwa000
Oct 2, 2009 10:19 PM
wildonev1
Sep 10, 2006 12:36 AM
