2004 1500 A/C Problems
Old Sep 2, 2010 | 11:19 AM
dbchevy's Avatar
Default 2004 1500 A/C Problems
I have a 2004 Chevy Ext Cab 1500, my A/C will randomly shut off while driving. I will turn off the truck for an hour or so and then the A/C will run fine. I have used gauges to check the fre-on and everything checks out ok. This doesnt happen everyday but i have noticed it on long drives.
Any feedback would be great.
DB
Old Sep 3, 2010 | 8:12 AM
CJ_Tiz's Avatar
Do a search in the forum. Its a common problem with Chevy trucks. I had the same problem with my truck except it would blow cold on pass side and hot on drivers. Then it one day the problem went away. It has something to do with dampeners in the dash getting stuck half open or half closed. Hope this helps a little.
Old Sep 3, 2010 | 11:25 AM
dbchevy's Avatar
I will look in to that, suggestions and tips can help me solve my problem.
Thanks,
Old Sep 3, 2010 | 8:24 PM
blaze_32001's Avatar
would you happen to know where the post is at? mine has started to do it. do you know it we can do anything to fix it?
Old Sep 4, 2010 | 7:53 AM
brady58's Avatar
Default blower/not ac
turn fan on. if ac light light comes on, ac probly ok .check wiring going in to blower fan\\I had same problem..with ignition on ,fan on high, wiggle the wire going in to the blower motor,,feel for heat in the wire,mostly around the plug at the blower motor.Bad fan OR damaged wire
Old Sep 4, 2010 | 11:46 PM
jwruss's Avatar
I had a similar problem in a 2001 Dodge truck, turned out to be the compressor clutch.
Mom2ThreeACG
Traverse
Mar 12, 2018 6:20 PM
mwehrste
Dec 29, 2014 11:19 AM
gjeepguy
Feb 6, 2008 4:01 PM
aunut5
Sep 26, 2007 4:39 PM
RWhiddon
Sep 7, 2006 1:32 AM
