2005 truck won't start
Old Jan 31, 2010 | 7:30 PM
praaa_5's Avatar
Question 2005 truck won't start
I have a 2005 Chev 4x4 1/2 ton with 305 engine. Intermitantly when you put in the key all of the dash lights come on but when I turn the key to start position, all dash lights go out except for engine symbol, but the engine doesn't turn over. The only way that I can get it to start is keep going back and forth with key until it finally kicks in. Sometimes it is a few few key turns next time it will be 30 or so before it kicks in. I took it to GM and they said it was a weak battery so I changed it, but that didn't help. It continues to do it and with no pattern. I have checked it the battery cables for tightness. Need some help.
Old Jan 31, 2010 | 10:40 PM
s34n's Avatar
starter could be going out or ignition coil. have you checked your plugs for spark?
Old Feb 2, 2010 | 9:11 PM
praaa_5's Avatar
I changed my plugs and plug wires last summer. After I had installed the new ones I did have one plug that was no good so they replaced it.
Old Feb 2, 2010 | 10:12 PM
gotstylez's Avatar
take it back to the dealer and tell then u changed the battery..if they try to kick you around and say well its this or this or could be that. tell them u need it looked at...what the volt meter say? does it say its charging and its around 12v or so?
ZChevyAK
Nov 13, 2015 6:45 PM
eem242
Dec 4, 2013 5:31 AM
HurleyDallas
Sonic (Aveo)
Jun 24, 2012 8:56 AM
bracca
Jul 12, 2009 6:14 PM
FamilyOf5
Jun 11, 2008 2:56 PM
