2005 truck won't start
I have a 2005 Chev 4x4 1/2 ton with 305 engine. Intermitantly when you put in the key all of the dash lights come on but when I turn the key to start position, all dash lights go out except for engine symbol, but the engine doesn't turn over. The only way that I can get it to start is keep going back and forth with key until it finally kicks in. Sometimes it is a few few key turns next time it will be 30 or so before it kicks in. I took it to GM and they said it was a weak battery so I changed it, but that didn't help. It continues to do it and with no pattern. I have checked it the battery cables for tightness. Need some help.
take it back to the dealer and tell then u changed the battery..if they try to kick you around and say well its this or this or could be that. tell them u need it looked at...what the volt meter say? does it say its charging and its around 12v or so?
ZChevyAK
Nov 13, 2015 6:45 PM
HurleyDallas
Sonic (Aveo)
Jun 24, 2012 8:56 AM
