2006 chevy-won't shut off
Old Nov 13, 2008 | 10:29 PM
sri's Avatar
sri
Default 2006 chevy-won't shut off
tried to start the truck after sitting for three weeks. Don't drive it much (23000 miles). Battery was dead, put the charger on after a few hours it started right up. The problem is it won't shut off. turn the key to off,take the key out of the ignition. still runs. Security lock light is on. Disconnected the battery,still runs. Finally pulled the fuel pump breaker and it shut down. Tried it a couple times still the same way.
Looked under main fuse block on fender for shorted wires etc. didn't see any shorted out. Any idea whatwould cause this. Will call dealer in the morning since it's still under warranty.
thanks
Old Nov 14, 2008 | 9:18 AM
therewolf's Avatar
Default RE: 2006 chevy-won't shut off
More than likely your ignition lock cylinder has become loose or disconnected from the ignition switch, lower on the steering column.
Once the system is up and running, disconnecting the battery doesn't help because it's running off the alternator. You'll probably find if you adjust the linkage between the cylinder and the switch it will solve your problem.
Old Nov 10, 2014 | 3:04 PM
chevy2006's Avatar
Have a 2006 hhr battery dead key wont come out
06ImpalaDriver
Apr 7, 2014 9:54 PM
nherweck
Nov 3, 2011 8:36 AM
Sub01
Dec 3, 2007 7:46 PM
genestoy
Feb 28, 2007 11:55 PM
hexman512
Dec 29, 2006 10:23 PM
