2007 1500 A/C has a mind of its own
Old Sep 24, 2012 | 9:19 PM
Bradc80's Avatar
Default 2007 1500 A/C has a mind of its own
My A/C has started to switch from blowing out of the front vents to the defrost vents but with cold air all by itself. I've noticed the air switches immediately when the passenger side door is closed shut or when I hit a bump while driving. When the air switches to the defrost vents it takes several attempts of flipping the A/C mode selector back and forth between the defrost & front vents to get the air to switch back. After doing some research it seems like I have a problem with a wiring connection that is causing my door actuator to switch to defrost. If this is the case, how & where should I check for that? Let me know what you think.
Old Sep 25, 2012 | 12:40 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Thank you for your purchase of the Chevrolet vehicle. I'm very sorry to hear about the issue you are experiencing regarding your A/C. Please PM me with the last 8-digits of your Vehicle Identification Number (VIN), and I will look into this further, thank you.
I look forward to your reply.
Jimbo B
Apr 24, 2023 9:23 AM
05cavalier
May 20, 2015 1:42 AM
98whitehoe
Mar 14, 2012 7:48 AM
kstough
Nov 18, 2011 9:38 AM
Buckhorn
Nov 6, 2011 8:23 PM
