2008 silverado windshield washer pump
Old Aug 10, 2012 | 8:37 PM
nbmech's Avatar
Default 2008 silverado windshield washer pump
Hello,
My 2008 silverado is having some electrical problems.
I parked it today at 1pm and left the area. When I returned at 6pm I heard a noise and found that the washer fluid pump was running. I also noticed tgat the daytime running lights were on, I disconnected the pump and pulled the fuse for the lights. The battery must be dead as it wont turn over. I am going to charge the battery tonight but need assistance with how to troubleshoot the problem. Any and all help is greatly appreciated!!
Old Aug 11, 2012 | 10:37 PM
jesse06's Avatar
did it rain hard there? something may have been shorting out
Old Aug 13, 2012 | 2:47 PM
Official GM Rep
Originally Posted by nbmech
Hello,
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> I'm sorry you are experiencing this issue with your Silverado vehicle. Would you please PM me the last 8-digits of your VIN, so I may look into this further for you?
I look forward to your reply.
Louis
GM Customer Service
Old Aug 14, 2012 | 8:03 PM
nbmech's Avatar
Hi Louis,
The last 8 #'s are 81113842.
Thanks
Old Aug 14, 2012 | 8:38 PM
does it have the heated washer reservoir feature or has it been removed already?
Old Aug 15, 2012 | 8:00 AM
nbmech's Avatar
I dont think it had the heated washer if it did how do i tell??
Old Aug 16, 2012 | 6:11 PM
should be a button in the center console below the hvac controls. A picture of the button should be in the owners manual.
Old Aug 24, 2012 | 7:18 AM
nbmech's Avatar
UPDATE...
It turns out the body control module, transmission control module, transfer case control module and engine control module were all bad. After talking with a neighbor he remembered hearing a close lightning strike. I guess that could have possibly caused the issue. The dealer is asking GM to assist with the repair cost.
Thanks for your help.
Railroadertwo
Oct 3, 2014 10:16 PM
kevinkpk
Aug 29, 2011 1:38 PM
CheesePuff
Dec 29, 2009 3:58 PM
diehard911
Jun 29, 2009 6:53 AM
