2011 Silverado ltz brake pedal 4 pin wire harness
Old Oct 7, 2022 | 6:50 AM
CCarver's Avatar
Default 2011 Silverado ltz brake pedal 4 pin wire harness
I have an issue with my traction control and stabilitrak system along with not being able to use my cruise control. I had seen where to check brake sensor and in doing so I found that the brake lights were not activating. Once I finally got myself under the dash and checking connections I began to grab a hold of the 4 pin wire harness and three of the wires just pulled off. Now I have no clue on the color coding to put back in correct order.
could someone explain the correct order? The one connected wire is blue/white. The remaining is orange/white, pink, and purple.
Old Oct 8, 2022 | 2:47 PM
Gumby22's Avatar
If the wires just pulled out of the connector, it probably needs replacement. Pigtail assemblies are available from parts stores or online.
The SMP part# is S1698
Order as follows:
Light blue/white
Pink
Orange/white
Purple
Old Oct 8, 2022 | 2:53 PM
CCarver's Avatar
Default Issue Resolved
Order as follows:
Light blue/white
Pink
Orange/white
Purple
I tried to find replacement terminals but no luck. Went to local junkyard, cut the connector needed and spliced together. All warnings have been cleared.
Thank you for the advise
danb113
Jul 15, 2010 5:07 PM
jpayne18
May 3, 2010 8:59 PM
shmee
Mar 16, 2010 3:45 AM
awp1965
Jul 22, 2009 9:20 AM
Scootertrash
Oct 11, 2008 10:48 PM
