2500hd stalls
Old Apr 4, 2007 | 8:34 PM
hiclena's Avatar
Default 2500hd stalls
2001 2500 hd 8.1 stalls,sometimes starts right back up or let set for few minutes and starts changed fuel filter and added heat to gas for incase of water, starting to happen more frequentley. Fuel pump??
Old Apr 5, 2007 | 12:24 AM
sm3earl's Avatar
Default RE: 2500hd stalls
Get a fuel pressure gauge, and check the pressure in the rail. then see if its in spec. If not, replace pump.
Old Apr 5, 2007 | 4:32 PM
hiclena's Avatar
checked pressure 55 psi inrail
Old Apr 5, 2007 | 5:03 PM
sm3earl's Avatar
is that spec in the book?
Old Apr 5, 2007 | 5:50 PM
hiclena's Avatar
spec 50 to 60 psi
Old Apr 5, 2007 | 5:52 PM
sm3earl's Avatar
ok, so maybe timing? have you checked that? how about spark?
Old Apr 7, 2007 | 7:19 PM
kcb37's Avatar
Did you check your fuel press running or with the key on? Sometimes they will hold pressurize the system then not be able to keep up.
Old Apr 7, 2007 | 9:54 PM
RonH's Avatar
My 5.7L Suburban did exactly the same thing -- would stall driving or idling, then start back after sitting for just a few seconds. It was the fuel pump. It would hold pressure for a while, then the pump would stall.
Old Apr 13, 2007 | 5:44 PM
hiclena's Avatar
crank sensor
Old Apr 13, 2007 | 8:15 PM
ZX1100F1's Avatar
I would tend to agree with RonH; just having what was written so far to go by.
Normally a fualty crank sensor will almost always allow a restart.
I have seen fuel pressure regulators cause stalling as well if the diaphram becomes ruptured.
oilyfishhead
Apr 1, 2011 5:11 PM
Jimbo302
Jan 7, 2007 5:21 AM
jak1320
Oct 16, 2006 1:32 PM
MYoung
Sep 27, 2006 2:44 PM
bodders
Jul 30, 2006 8:21 PM
