4L80E trans flare up
Old Oct 7, 2014 | 12:51 PM
Sctmcly's Avatar
Default 4L80E trans flare up
Hi everyone,
I have a 2004 Silverado 2500 (non hd) when I accelerate lightly, between the 2-3 up shift, it seems to flare up before completing the shift. Only by a couple hundred rpm. Any thoughts?
Old Oct 8, 2014 | 12:30 AM
89scottsdale's Avatar
so what you are saying is the tranny seems to be missing a shift? or the motor is revving to get to the shift?
Old Oct 8, 2014 | 9:58 AM
Sctmcly's Avatar
The engine is revving up 2-3 hundred Rpm between that shift. Like it was slipping. Doesn't happen on a hard accel though.
Old Oct 8, 2014 | 11:24 AM
Allan In NE's Avatar
Are you sure this isn't a 4L60E? 4L80 uses a stacked shift, whereas the 4L60E has a timed shift.
Allan
Old Oct 9, 2014 | 12:40 PM
Does the fluid Snell burnt or is it low?
Old Oct 12, 2014 | 3:55 PM
Sctmcly's Avatar
Fluid is full and smells good. And yes, is Is a 4l80e
Old May 7, 2020 | 12:54 AM
Sh!tboxer's Avatar
Following..mine is doing the same, no rhyme or reason, does it one day, might not do it again for weeks... never flares in tow/haul mode...only easy driving to work...
Old Nov 4, 2023 | 11:11 PM
JCSilv's Avatar
Default 2000 25000 nonhd
My Chevy 2500 Silverado 373 rear end gears when I have no trailer attached sometimes it shifts sort of hard between second and third and seems like the overdrive is comes and goes but when I have a trailer and loaded it never shifts hard like that and I wondered if it was something solenoid or something like that before I go change the transmission any ideas
Old Nov 5, 2023 | 6:51 AM
Originally Posted by Sctmcly
Hi everyone,
Leaky seal or wobbly piston on either the 1/2 or 3/4 accumulator.....
lsswaped93
May 20, 2017 7:21 PM
donsjimmy
Mar 24, 2014 1:22 PM
700xcsp
Feb 13, 2011 4:00 PM
emtzach
Sep 20, 2010 1:43 PM
bobbyt
Mar 10, 2007 10:25 PM
