88 chevy k1500 reverse problems
Old Mar 16, 2014 | 8:33 PM
padilla's Avatar
Cool 88 chevy k1500 reverse problems
when i go thew the gears P R N D 123, my reverse light go on and than goes off,want i stop on reverse why? can someone help. all my lights work fine, back up, turns and brake, but not the reverse.::
Last edited by padilla; Mar 17, 2014 at 2:59 PM. Reason: gera set up wrong, it sure be P R N D D 1 2
Old Mar 17, 2014 | 4:27 PM
bigbadbowtiegirl's Avatar
The light on the Cluster? or the actual reverse lights?
Old Mar 17, 2014 | 7:02 PM
padilla's Avatar
my reverse lights and lens, connect are new... question on cluster, what light? my reverse
flashes as you go by the gears, when you stop on reverse nothing.
Old Mar 18, 2014 | 2:25 PM
Sorry, the cluster thing im thinking of newer body style. If it flashes but does not stay on when shifted into reverse, it can be an issue the neutral safety switch on the side of the transmission. Might be something simple as and adjustment or may need to be replaced.
Park/Neutral Position and Backup Lamp Switch Adjustment
  • Check the switch for proper operation.
  • The engine must be in the P (Park) or N (Neutral) positions only. If adjustment is required, loosen the switch retaining bolts and rotate the switch slightly.
  • Tighten the bolts and check the switch for proper operation.
  • Repeat the switch adjustment procedure until the engine starts when the shift lever is positioned in park and neutral.
Old Mar 26, 2014 | 2:15 PM
padilla's Avatar
Had to buy a new shift indicator, than i adjusted the neutral safety switch..now everything is working. Thank you very much Joe
bioDAWG
Jan 18, 2019 7:09 PM
shaffer21
Feb 19, 2015 8:31 AM
LoudSuburban
Dec 4, 2014 7:11 PM
Morphsuit
Oct 8, 2013 6:06 AM
cam4
Aug 12, 2010 1:25 PM
