92 silverado swap throttle bracket issue-please help!!!!!!!!!
Old Dec 11, 2012 | 10:38 AM
vtwincrazy84's Avatar
Default 92 silverado swap throttle bracket issue-please help!!!!!!!!!
Hello folks,
I am having a hell of a time figuring out the proper mix for this setup. I have a real basic issue, but its a pain in my you know what. I recently purchased a 92 silverado with automatic 700r4 4x4. it had a 4.3L boat anchor that i took out of it and replaced it with a sb chevy 350. It had tbi i switched over to carb. Currently i am using a Professional Products Cyclone Intake Manifold 52001 setup with a 1979 rochester 4bbl quadrajet. I have used multiple universal throttle brackets and nothing has worked. the stock bracket off the 350 and the 4.3 also failed to work. Since this is my first time switching over from tbi to carb on this type of motor, i am uncertain as to what i need. I need to know what length throttle valve cable i need and also what bracket i need. Does, jeggs, summit or another like supplier have such a bracket? Please keep in mind the intake and carb i am using. I have tried many universals and none have worked. if anyone has ran into this issue before and can help, please do! I'm desperate and need this truck driving on its own power asap.
Old Dec 11, 2012 | 4:17 PM
Really!! 108 views and no replies? Come on people. We can do better than this.
Old Dec 11, 2012 | 7:49 PM
chevyboy1993's Avatar
i'm not really good with throttle brackets but i think you may be better off going to a boneyard and getting the entire bracket setup off of an older 350 with carb setup
Old Dec 11, 2012 | 10:13 PM
Default Clarity
Sorry, should have been more clear. I currently have a bracket off a 350 that had a carb setup. I also have the bracket off the 4.3L and two universal brackets. The problem lies mostly in the intake. The mounting locations for any bracket using that intake just don't jive.
Old Dec 12, 2012 | 7:33 PM
could you make a relocation bracket that take the original bolt holes from the manifold and move it so it's more in line to use one of the brackets? just a simple 1/16" plate with a little angle spot to raise it up a tad so you can bolt the bracket on, of the distance you need to make it work
Deek
Jun 10, 2015 11:15 PM
Z71lover24
Sep 29, 2013 11:21 PM
Chad Cratsenburg
Oct 15, 2012 4:57 PM
biglg
Mar 8, 2010 3:28 PM
