98 silverado 5.7 cranks but no start?
Old Nov 26, 2010 | 4:16 AM
Pinkypinks's Avatar
Default 98 silverado 5.7 cranks but no start?
So the truck was doing a thing where it would start perfect when cold and then i would go to the store and come out and try and start it and it would crank and crank and barely start.
So now it just wont start at all. I checked for spark, removed the fuel filter and cranked to see for fuel pressure and both were good, i changed the crankshaft position sensor cause i heard those go bad and still no start.
If any one has any ideas i would apprexiate it thank you
Old Nov 26, 2010 | 6:02 PM
98ChevyGuy's Avatar
Have you checked the altenator or your battery?
Old Nov 26, 2010 | 6:33 PM
Pinkypinks's Avatar
Yes i did...
Old Nov 27, 2010 | 12:47 AM
mossheg's Avatar
I might be late, but:
I don't know if it's the same problem, but my Blazer did the same thing. I knew it wasn't the battery, because the lights worked perfectly, and the crank was very strong and continued. Turned out to be a broken Fuel Pump, which is what I thought from the beginning. It might also be your Timing Belt gone bad.
Old Nov 27, 2010 | 2:19 AM
Pinkypinks's Avatar
Im gonna buy a fuel pressure gauge and see what the actual psi im getting.
50 calls it good correct?
Old Nov 27, 2010 | 2:55 PM
mossheg's Avatar
I think that sounds about right.
Old Nov 27, 2010 | 10:28 PM
OLD WRENCH's Avatar
Put some gas in a squirt bottle and give her a gargle and see if it fires. If it does this will tell you its a fuel problem. If it doesnt better look to ign.
I dont think a chev 5.7 has a timming belt.
Old Nov 28, 2010 | 2:04 AM
silverado13's Avatar
not a belt but it has a chain, could have a possible broken sprocket
kenehsr
Sep 5, 2010 5:08 PM
PrecisionAuto
Nov 24, 2008 11:42 AM
elviejo59
Aug 6, 2008 8:14 PM
74chevy4life
Feb 14, 2008 10:13 AM
mike78olds
Sep 17, 2007 9:33 AM
