brake problem
Old Jul 28, 2007 | 4:48 PM
chevy3quarta's Avatar
Default brake problem
my bleeders are stripped, how do i bleed the brakes otherwise? i know it can be done, i just dont know how to do it.
Old Aug 4, 2007 | 5:44 PM
BigBoom360ci's Avatar
Default RE: brake problem
Well I would be trying anything to get those bleeder valves out and replacing them then bleed the system.
Old Aug 6, 2007 | 6:09 PM
kcb37's Avatar
If you can get them out with plyiers or vice grips you can put new one's in. If you completely destroy them and don't want to put on new calipers you can crack the line. It won't work as well because it won't be able to push the air thru the caliper, but it should work fine.
Old Aug 7, 2007 | 3:11 PM
how do you crack the line? bleed it through the end of a brakeline?
Slobby Baymon
Nov 12, 2013 11:52 PM
cmcbride
Avalanche
Aug 8, 2012 3:12 PM
Thad W. Posey
Jun 15, 2012 9:21 AM
tom5170
Mar 19, 2010 11:57 PM
