Can 97 Silverado rear diff be filled from breather ?
Old Jun 15, 2014 | 2:59 PM
jsepps's Avatar
Default Can 97 Silverado rear diff be filled from breather ?
I recently did some work on my diff. (seal and pinion). I overlooked how bad the fill plug was rusted but regardless the work had to be done.
I'm wondering if the diff can be filled from the breather and if so how much oil.
Does the oil have to be synthetic?
Thanks
Old Jun 15, 2014 | 3:55 PM
sledge.impy's Avatar
I don't see why not. I think I added some oil or limited slip differential additive through it once.
You just risk overfilling.
How is it rusted? The threads should be fine and you shouldn't have issue removing the plug.
Old Jun 15, 2014 | 5:00 PM
jsepps's Avatar
The hole for the ratchet drive is corroded. I don't think it will come out without stripping. I'm gonna try like hell but I doubt it gonna happen. Therefore I made this thread if need be
Old Jun 15, 2014 | 6:46 PM
Not sure if PB blaster will help on the outside for the threads.
Do you think it will seriously round?
Good luck!
Old Jun 15, 2014 | 7:15 PM
jsepps's Avatar
Thinking about getting some Kroil to try on it
Old Jun 16, 2014 | 6:49 PM
jsepps's Avatar
Any idea how much juice ?
Old Jun 16, 2014 | 9:03 PM
Not sure I understand the question?!
Old Jun 17, 2014 | 5:14 AM
jsepps's Avatar
How much gear oil ?
Old Jun 17, 2014 | 7:27 AM
How much gear oil ?
No. Usually you just fill it up until a little runs out of the fill plug hole.
There's no way to determine that I'm aware of, if you go through the breather.
Of course you collected all the lost gear oil and have measure it and can use that amount to determine how much to put back in???!
keown1996
Oct 27, 2013 6:38 PM
Brian London
Dec 12, 2011 10:30 PM
memphizballa
Jul 2, 2011 8:40 AM
07impalaSS
Dec 23, 2007 10:07 PM
