Chassis Lubrication
Old Jul 11, 2010 | 7:46 PM
JK23112's Avatar
Default Chassis Lubrication
I bought a tube of grease today -- the red kind that is supposed to be good for "high temperature" use. It was the most expensive, at about $3.50 for a tube.
I plan to lube the chassis of my 2004 Silverado sometime next weekend. Is this "red" grease good enough? I think red is synthetic grease, right?
How many fittings on there (driveshaft and suspension, etc.) if the truck is 2wd with the 5.3L V8 engine? BTW, it has an automatic transmission.
THANX!!!!
Old Jul 11, 2010 | 8:25 PM
s34n's Avatar
i know there are zerk fittings on the upper and lower ball joints, pitman arm, idle arm, steering linkage. i cant remember if there are any others. i use the same grease so you shouldnt have problems.
Old Jul 11, 2010 | 8:40 PM
The high temp rating is best suited for wheel bearings.. the chassis is not as likely to get hot like the wheel bearings would, however the grease should work thou you shouldn't base price as equaling better.
Your owners manual should provide a listing of suitable lubricants for your vehicle, the tube of grease should also list its recommend uses.
Jerry32
Sonic (Aveo)
Jun 17, 2013 9:33 AM
tbb2
Aug 24, 2011 2:48 PM
tbb2
Jul 31, 2011 4:21 PM
in2pro
12
Nov 15, 2010 11:40 PM
exuL1B47
Apr 30, 2009 8:26 AM
