cheap intake
Problem with that is if you ever want to sell the truck you will have a butchered box....I for one would not want to purchase a truck like that.
I would suggest purchasing a K&N kit. You can select the year of your vehicle to see what is available here
Chevrolet Silverado 1500 Air Intake Kit - 1999 - 2005 2004 2003 2002 2001 2000 - TheAutoPartsShop
The items that show "1 in stock" may not be immediately available
yes you COULD cut the bottom out, but I've said before that wouldn't make much of a difference since the side entrance through the fender flows very well. If if makes you feel better then cut away. It only take 20 min. at the most
Actually, I put in a replacement tube with kn filter using the stock box. I developed a very annoying resonating sound under partial throttle with a load. So annoying that after several attempts to resolve it failed, I went back to stock. I would recommend going with an actual kit that bypasses the fender area.
Just my .02
Eric
Just my .02
Eric
I dunno, that was my experience. I have since replaced my 08 4.8L with a 6.0L vortec max. I am looking forward to getting the base cold air kit from KN. Won't do the tube only thing. Just had a bad experience. Will do the actual plastic tube kit with the exposed cone filter.
weld234
Feb 4, 2011 8:18 PM
