Chevy 1500 tbi problems
Old Jun 21, 2012 | 11:38 AM
fastbob67's Avatar
Default Chevy 1500 tbi problems
Hey guys trying to find out what can cause my truck to get prime. I have already replaced the fuel pump the pump relay . I can pour some fuel down the tbi and runs until i shut the truck back off . I also checked to make sure the pump is running in the tank and it is . I also checked to make sure i have power at the fuel pump relay and i get 11.8v when i check .
Old Jun 21, 2012 | 12:58 PM
kevinkpk's Avatar
I'd be nice to know what year ect. Does it have emissions on it?
Old Jun 21, 2012 | 1:21 PM
fastbob67's Avatar
the truck is a 1995 and it has all the emissions on it
Old Jun 21, 2012 | 1:34 PM
kevinkpk's Avatar
Is the check engine light on?
Old Jun 21, 2012 | 2:25 PM
fastbob67's Avatar
no i think i may have found the problem .I have a neighbor who has a tbi on his truck and when you start to crank the truck the fuel starts to spray down the throttle body and mine is not doing that. If i am getting power to the injectors it should spray fuel down the intake correct.
Old Jun 21, 2012 | 8:07 PM
chevyboy1993's Avatar
check the ignition control module
Old Jun 22, 2012 | 8:26 AM
fastbob67's Avatar
Yeah i think everybody is telling me to look at the icm in the the truck
Old Jun 22, 2012 | 1:48 PM
had same problem on 92 s10. replaced everything you did and when finally got it to fire i noticed the injector spray was weird so i called a friend who is gm master tech and he said the icm controls the injector pulse. it's about 25 bucks
Old Dec 2, 2012 | 8:58 AM
SgtBummrush's Avatar
I have a 1995 1500 v6 2wd with the same problem replaced fuel pump and sending unit.replaced relay but noticed there is no power to the fuel pump relay. If i spray or pour fuel in bowls it will run for a few seconds. I am really stumped has anyone found a solution?
Zachwooten
Apr 26, 2012 9:13 PM
idorace
Nov 3, 2011 11:40 PM
duffman770
Jul 5, 2011 10:29 AM
czarmatra
May 13, 2007 7:16 PM
czarmatra
May 12, 2007 1:16 PM
