Cruise Control Problems on a 2008 Silverado
Old Oct 13, 2011 | 11:54 AM
psupgm's Avatar
Default Cruise Control Problems on a 2008 Silverado
Anyone have an idea what the cause of my cruise control not engaging unless I use my foot to pull the brake pedal up after braking? It doesn't appear the pedal moves at all when I do this but the Cruise Control will only work when I do this. Thanks!
Old Oct 13, 2011 | 5:54 PM
EinST's Avatar
Welcome to the forum. It sounds like you've found your problem. The brake light switch actually has two switch circuits, one for the BCM and the other, the ECM. I think the one for the BCM is not closing properly which causes the BCM to ignore the cruise control signals from the buttons on the steering wheel.
Old Oct 14, 2011 | 7:41 AM
psupgm's Avatar
Thanks! I assume just replacing the switch we solve the problem?
Old Oct 14, 2011 | 11:36 AM
EinST's Avatar
It's probably the switch if you see signs of excessive dirt or water intrusion (rust on the brake pedal). Also, try repositioning the wiring harness to make sure there's nothing funny going on at or near the switch electrical connector.
Old Oct 15, 2011 | 8:30 PM
psupgm's Avatar
Cleaned it and creased it, all is working well. Thanks for your insight.
Old Oct 15, 2011 | 8:46 PM
EinST's Avatar
You're quite welcome. Hope that's all there's to it.
Old Oct 3, 2013 | 3:40 PM
stu carlon's Avatar
I have the same issue. I just installed a new switch and it didnt fix the problem. Im going to have my mechanic friend check for a code. I'll update soon.
Old Sep 30, 2015 | 9:54 PM
Asnyder's Avatar
I have a 2008 3500 HD WT. I want to replace the steering wheel with one that has cruise control buttons. Is the truck prewired for cruise control?
GradyCheek
24
Mar 3, 2025 7:32 AM
crwalker2
2007 - 2013 (GMT900)
94
Aug 28, 2024 3:27 AM
Relayer56
Avalanche
18
Mar 29, 2021 10:43 AM
Swampy
17
Oct 26, 2015 1:35 PM
sssilverado23
Aug 30, 2012 3:09 PM
