electric fans on 04
is there an electric fan set up that works with a thermostat like factory for the 05 and up or is there a way i can make a factory set up work reliably i want my 10 hp back the mechanical fan steals
Shop around junkyards for the fans and radiator...cheaper way is to find some ls1 fans from a Camaro I believe..they bolt right up to the 28" radiator you have(may want to measure) and then the tune from Blackbear is like 250 I think. So maybe 500 to do it all if you go with the 05+ setup
Does this mean that I need to get a programmer in order to install the tune from blackbear? Will the Blackbear tune interfere or write-over my current tune? Can I program the electric fan with a DiabloSport Predator tuner? Lots of questions. Thanks for your help and advise so far!
cams 98 silverado
Aug 17, 2009 11:19 PM
