Engine Coolant Tempature Sensor and Wiring
Old Apr 24, 2014 | 4:34 PM
Minnesotasnowman's Avatar
Unhappy Engine Coolant Tempature Sensor and Wiring
I have a 2006 3500HD with a Duramax. I am getting a check engine light and code p0118. Ihave replaced the engine coolant temp (ECT) snsor and still have the problem. The hot wire is sending 4.96 volt to the sensor when I use an the engie as a ground. When I check voltage between the two wires in the plug, I only read 2.5-3.0 volts. Is that normal or do I have an issue a wiring issue?
Ernie1954
Jan 9, 2025 10:40 PM
Minnesotasnowman
Apr 24, 2014 3:44 PM
8k15009
Dec 28, 2012 6:44 AM
joshuasoileau
Mar 21, 2012 9:23 PM
SEAN
Sonic (Aveo)
Oct 9, 2010 6:44 PM
