Exhaust problems
Old Sep 26, 2011 | 8:49 PM
twilso23's Avatar
Default Exhaust problems
I recently went to put headers on my 95 k1500 with a 350 TBI and I discovered that there were two broken off bolt into the head. I fixed the one on the passenger side with a heli coil but on the drivers side i drilled the hole too far to the exhaust port coming out of the head and it is now connected to the exhaust port in the head. It was the 7 cylinder exhaust port. How can i fix this problem? Is it time for a new head or is there another way to fix this without taking the head off?
Old Sep 27, 2011 | 11:03 AM
slw210's Avatar
The new bolt should seal it up.
Old Sep 27, 2011 | 5:57 PM
twilso23's Avatar
Now the problem is that the hole doesn't align so I will need to drill anther hole to line the header holes up. When I do that it leaves the hole not plugged. Is there some kind of sealant to put in there that will not break apart as soon as you start the engine.
Old Sep 27, 2011 | 8:10 PM
Mille Racer 69's Avatar
What headers did you go with?
Old Sep 28, 2011 | 8:48 AM
twilso23's Avatar
I'm not sure I if I should buy some new or used ones but I have a set of 305 heads off a 93 pickup.
Old Sep 28, 2011 | 9:22 PM
twilso23's Avatar
Default Heads
Will a set of 305 heads from a 93 pickup fit on and work on a 95 350 TBI?
Mom2ThreeACG
Traverse
Mar 12, 2018 6:20 PM
amurra11
May 24, 2015 11:03 AM
mwehrste
Dec 29, 2014 11:19 AM
mackenziechris16
Apr 6, 2012 11:57 AM
lmf96z71
Sep 11, 2007 2:58 PM
