??? Flashing Parkimg Brake Light ???
Old Sep 1, 2007 | 11:16 AM
pickeral's Avatar
Default ??? Flashing Parkimg Brake Light ???
I have a 1988 Silverado with a Parking Brake Light that flashes consistantly when parking brake is released... Ten times and then pauses onthe tenth flash...Manuel tells me nothing about this...Could it be a warning of some problem???
Old Sep 1, 2007 | 11:50 AM
kcb37's Avatar
Default RE: ??? Flashing Parkimg Brake Light ???
Look at the parking brake switch and see what it looks like. It may be old and bouncing around makes it contact. I don't think your parking brake light will set a code, or is for any kind of warning.
Old Sep 2, 2007 | 6:42 PM
pickeral's Avatar
No it's not the switch.....Been doing this flash for months at this regular beat....Has to be some other reason...
Old Sep 2, 2007 | 11:02 PM
RonH's Avatar
This may be an error code for an early anti-lock brake system. Check the brake fluid level in the master cylinder. Go by a brake shop and ask them about T-codes.
Your vehicle should have anRWAL (rear wheel anti-lock) module. Locate it and unplug it and see if the flashing stops. Unplugging it and then plugging it back in may clear the code.
Old Sep 5, 2007 | 3:51 PM
golfer's Avatar
I have to agree with RonH.
There's likely a problem with the RWAL system. Check to see if the module is located in the engine compartment below the master cylinder.
First thing is check to see if the brake lights are working since the brake light switch is part of the RWAL system.
Check these preliminary things :
1 - make sure the brakes , calipers and wheel cylinders are in good condition
2 - check the electrical connection at the control module
3 - check the fuses
4 - follow the wiring harness to the speed sensor and brake light switch to make sure all connections are secure and the wiring isn't damaged
If all else fails you might have to take in somewhere.
Old Sep 5, 2007 | 11:28 PM
melat70's Avatar
I had a 91 silverado 2500 HD that did exactly the same thing and I found that the anti lock computer went south. A new part fixed the problem.
Mel
Old Sep 13, 2007 | 6:44 PM
pickeral's Avatar
Thank You;Ronh and Golfer.Problem solved.
2 - check the electrical connection at the control module .
Old Sep 14, 2007 | 9:47 AM
golfer's Avatar
It's nice when it's a simple thing and pretty cheap to fix.
jg33
Jan 3, 2021 3:17 PM
curiousvi
Apr 19, 2017 11:04 PM
SuperTexan
May 1, 2012 6:46 PM
70mopar
Oct 26, 2006 8:59 AM
mitchwrx
Jun 20, 2006 5:19 PM
