fuel gauge ???
Old Nov 17, 2010 | 10:06 PM
bob450's Avatar
Default fuel gauge ???
I have a 2001 silverado with the 6.0 in it. The fuel gauge will read empty when full and bounce back and forth also. I had another 2001 that had the same problem, any of you guys have this problem, and how did you fix it? Thanks Bob
Old Nov 18, 2010 | 7:32 AM
jlutty3's Avatar
I had a similar issue with a 96 Impala SS I just got out of storage this Summer.
Back then, there was a thin, brass wiper attached to the float arm on the pump assembly that rubbed along a wire wrapped around an arched plastic bar that sent the signal to the gauge. It sounds like yours is making contact off and on. No signal= "E".
Could be the fuel gauge, the circuit, or the sender on the fuel pump assy.
Mine was messed up from sitting for 11 years without moving on a 1/2 tank of gas mixed with Stabil
You might check the wire connections going to the pump assembly on top of the tank, check the wires and see if they are rubbing on something else, check voltage at the plug itself, or pull the pump, plug it back in, and wiggle the float to see if it works with a little sideways pressure on it.
I hope its the plug. Good luck!
Old Nov 18, 2010 | 1:59 PM
silverado13's Avatar
replace your fuel float and youll be good to go
Old Nov 19, 2010 | 9:06 PM
just out of curiousity, do you have the LQ4 6L or LQ9?
Old Nov 19, 2010 | 10:36 PM
old dog's Avatar
Default not quite sure !
yes it is a common problem it is the fuel level sensor on the in tank pump assembly ,i have the same 2001 2500hd w- 6.0 and it does the same thing . i am just not quite ready to spend the serious coin to repair it .
JohnG20
Oct 12, 2013 11:26 PM
santa6
Jun 23, 2013 2:14 PM
hfdff
Jul 26, 2010 9:09 PM
scottkern3
Dec 7, 2009 7:53 PM
wrxsubaruwrx
Dec 3, 2006 12:33 PM
