Hard Idol on Cold Startup
Hello, new member here...
I just got my 2001 Silverado 1500 with the 5.3 La few months ago.....and I'm not very mechanically inclined to troubleshoot this problem. Recently it has been having an extremely hard start up and idol on cold mornings, after the truck is started it seems to idol around 2500 rpm then jump back down to 1500 rpm... and sometimes die.
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf?file=http://vid86.photobucket.com/albums/k84/i_ammetal/1209091302.flv">
What could cause this?
Also in the video, you notice the low fuel light came on, i filled my tank two days ago... could that just be a bad sensor or something else?
Thanks
Thanks
Professional Mechanic
The 5.3 engine suffers from faulty intake gaskets. This is the common symptom. The gaskets have been updated by GM. The new ones will be a different color.
CodySchroeder94
April 7th, 2012 12:41 AM
waterwagen
November 17th, 2007 12:20 PM
