HELP! I have a real power problem!
Old Feb 16, 2010 | 7:12 PM
chevyfan78's Avatar
Default HELP! I have a real power problem!
My 96 Chevy k1500 has a major power problem. It's a standard and when I'm doing 50 in 4th it's got no power, at 60 it has no power...lol. I step on the gas and it goes NO WHERE! I am replacing the cat and Muff this week....I have already done a knock sensor, pcv valve, rotor, cap, wires, plugs....not the egr yet, but thats next....Im thinking about a chip mod and a cold air k&n intake kit....but after that im stumped. What else can effect the power? Im not a mechanic, just mechanically inclined...lol. Any help would be greatly appreciated!
Old Feb 16, 2010 | 7:21 PM
s34n's Avatar
possibly tps.
Old Feb 16, 2010 | 7:22 PM
maxxman04's Avatar
clogged fuel filter, clogged air cleaner. putting a chip and cai won't cure current problem. best to figure out what's wrong first, then put mods on.
Old Feb 16, 2010 | 7:23 PM
ristpin's Avatar
V6 or V8? Have you checked the throttle position sensor? Only in 4th gear? Have to ask, is the clutch slipping?
Old Feb 17, 2010 | 8:24 AM
chevyfan78's Avatar
its a v8 305 5.0...It does act worse in 4th than the others gears but the clutch isnt slipping at all....
Old Feb 17, 2010 | 6:34 PM
s34n's Avatar
i would place my bet on the tps.
Old Feb 18, 2010 | 6:56 PM
chevyfan78's Avatar
Ok, I replaced the tps today and there was no change...lol...at least it wasnt too costly it was only $35...anything else that could cause "no power" ...I need to keep the engine around 2500 rpms to have any power....
Old Feb 18, 2010 | 7:21 PM
therewolf's Avatar
Check very carefully around your whole top end, It could be a small vacuum leak.
You can check it easy with a vacuum gauge.
If your system has a distributor, my guess would be either a bad rotor, or a cracked or carbon-tracked distributor cap.
Old Feb 18, 2010 | 11:13 PM
chevyfan78's Avatar
I just did the plugs, wires, rotor and distributor less than a month ago....but I will check for a vacum leak.....
Old Feb 18, 2010 | 11:28 PM
chevyfan78's Avatar
dumb question, I did just up my tire size from 245 to 265 ....could the extra tire be causing my problem? They are a little taller than the old ones but not much...
yukon2001
Oct 30, 2012 8:53 PM
sneaky344
Oct 27, 2009 3:00 PM
4dartist
Jun 2, 2008 8:39 AM
st3ph3n
May 22, 2006 11:01 AM
