Hydro locked? What did i do? Plz help!
Old Sep 15, 2013 | 10:13 PM
eddiebray73's Avatar
Unhappy Hydro locked? What did i do? Plz help!
Hi im new to the forum!
So yesterday i took my 04 silverado 4x4 with the 4.8 through a "mud pit" that consisted of mainly water. It was about 2 feet deep give or take. I hit it realy fast and all of a sudden my motor suddenly stopped. I cranked it over an finaly it ran at about 200 rpm (amazing) and reved it up to where i droped it into gear an it hauled out, it jerked allot an when i came to a stop an poped my hood, my airbox was full of water an the container in the air intake had about a half gallon of water in it, i drove it home after emptying it(about 10-15 mins) it seamed to have a miss when i tried giving it allot of gas, i checked the oil and it seamed slightly milky but it could be fine, an noticed my coolant was slightly lower and i could smell coolant being burned out the exhaust but didnt see any steam. So the question is what procedure should i take? Did i blow a head gasket? Crack a head? Crack the block? It didnt hydrolock cuz the motor started up after right? Please help, i dont wanna tear it all down to find nothing wrong
Old Sep 16, 2013 | 7:36 AM
Welcome to the forum...
You stated the oil was milky... that is water in the oil. My concern with that is the that it was driven for a period after that water int he oil and that most likely has damaged or shorten crank, cam and rod bearing life...
Old Sep 19, 2013 | 10:31 PM
therewolf's Avatar
Hi eddiebray73,
Welcome to the Chevy Forums.
I would clean the MAF sensor, change the oil and filter,
and borrow a code reader from a buddy, and do a OBD
code check, and run a compression test.
But I tend to over-think these things, from time
to time. IME, however, lack of coolant will crack a
block, whereas any contact with any water will usually
only draw off heat.
shayandude
Jun 4, 2022 4:10 AM
Chevy199693
Mar 25, 2015 12:00 AM
Big tiny
Jul 28, 2011 11:51 AM
rooneyassoc777
Jul 28, 2008 7:20 PM
Hbhalibut
Jun 8, 2007 8:47 PM
