Ignition
The wife took the truck and you got it--its broke. It is a 1989 silerado stepside with the efi 350. The key turns to accessory but will not go further its lke locked, What could it be? please help--- Peter[
You can try to take the steering wheel off and see if the linkage is bent or broke. If you want to be simple and make it running and drivable you can run a wire from the starter main power to a switch to the starter selinod. It won't be right but if the wheel will unlock you will be able to drive it.
If the key was wore out it would most likely turn forward start turn back to run and you would be able to pull the key out, then shut the truck off with or without the key but not be able to turn the ignition after it was locked. even if you turned to run and had a wore out key you should be able to start it without a key. That dosen't sound like a wore out key to me.
mikeski
Feb 16, 2006 9:41 PM
