Loud roar at 55
Loud roar at 55
Hey everyone i'm a new member and long time chevy lover! I have a 95 silverado ext cab with a 350 and 5 speed manual trans. At about 55 to 60 mph i have a loud roar inside the cab. No vibrating just a roar and it doesnt do it unless i'm from 55 to 60. Could i be the midshaft bearing? I crawled under and moved the drive shaft around a little, there was maybe 1/4inch of movement. Any ideas would be very helpful.
no i just got the truck. it tuns and drives out great. the noise is just irratating. checked the trans and rearend fluid. its full. and as far as i can tell by turning the driveshaft the universals are in good shape
could be tires.. one might be wore differently..happened on my 95 when i had stock tires on it.. happened when i rotated tires..transfer case could be stuck in 4wd..but you said no viberation.. doubt that but you never know
Chevy07
May 14th, 2014 4:31 AM
ndb1983
May 30th, 2011 8:03 PM
lifted06
May 6th, 2011 12:34 PM
