Loud roar at 55
Old Mar 28, 2011 | 7:38 PM
nightrain99's Avatar
Post Loud roar at 55
Hey everyone i'm a new member and long time chevy lover! I have a 95 silverado ext cab with a 350 and 5 speed manual trans. At about 55 to 60 mph i have a loud roar inside the cab. No vibrating just a roar and it doesnt do it unless i'm from 55 to 60. Could i be the midshaft bearing? I crawled under and moved the drive shaft around a little, there was maybe 1/4inch of movement. Any ideas would be very helpful.
Old Mar 28, 2011 | 9:49 PM
Big Chuk's Avatar
Check the fluid level in your Transmission.
Old Mar 29, 2011 | 9:23 AM
OLD WRENCH's Avatar
Did this just start suddenly or has it came on gradually. Have you done any work to the trk. prior to noise?
Old Mar 29, 2011 | 7:52 PM
no i just got the truck. it tuns and drives out great. the noise is just irratating. checked the trans and rearend fluid. its full. and as far as i can tell by turning the driveshaft the universals are in good shape
Old Mar 30, 2011 | 1:41 AM
OLD WRENCH's Avatar
A drive shaft brng should be noticable at most any speed. You might check the ex. to see if it is contacting anything.
Old Mar 30, 2011 | 2:40 PM
i'll do that it does have duall exhaust that i need a good reason to make different. thanks for the help buddy
Old Mar 30, 2011 | 3:47 PM
gotstylez's Avatar
could be tires.. one might be wore differently..happened on my 95 when i had stock tires on it.. happened when i rotated tires..transfer case could be stuck in 4wd..but you said no viberation.. doubt that but you never know
Chevy07
May 14, 2014 4:31 AM
tiso_us
Feb 23, 2012 1:37 PM
ndb1983
May 30, 2011 8:03 PM
lifted06
May 6, 2011 12:34 PM
