Mirror with temp and compass
Need some info. I just replaced my mirror (06 Silverado WT)with the mirror with the temperature and compass. The compass works is there a module I need to add for the temperature gauge?
Thanks
Thanks
RE: Mirror with temp and compass
I thought about buying one and looked at the kit, there should be a probe attached to a cable that needs to be routed out of the vehicle.
Someone else might chime in the to standard location where it attaches to.
What did you pay for your mirror and where did you buy it?
Needs to have a ambiant temp sensor. it should sit just in front of radiator on core support. needs to wired directly to rear view mirror.
Off E Bay, cost was $23.98 with shipping. Looking at other posts on this forum I think the temp sensor is available from Chevy for under $10.00, It attaches to the left side of the radiator shroud. I will call chevy tomorrow and post the results part # ect.
ORIGINAL: kirchc
cheers
Connecting the mirror and getting the Temp dispay to work is a breeze if you get the ambient temp sensor.
If you want the Electrochromic auto-dimming feature to work then you also need to connect a few more wires (back-up lamp relay wire, Auto Day/Night signal wire etc) to the mirror.
ORIGINAL: ZX1100F1
thanks!
I picked up the sensor off e bay as well, not I just need to find the wiring. Can anyone look at there 06 1500 and tell me where the sensor is located. My guess is that the wiring is there I just need to know whick one it is.
thanks
thanks
flbeachfront
October 21st, 2021 5:26 PM
bartmav
September 23rd, 2011 8:47 PM
blue05
September 15th, 2010 10:33 AM
pcar996
August 12th, 2008 10:21 AM
