Misfire
Old Feb 29, 2012 | 4:39 PM
jpolk1's Avatar
Default Misfire
I've got a 2000 chevy z71 5.3 with 150,000 miles on it. The problem I'm having is while the truck is at a Idole it has a misfire. Doesn't skip while going down the road. The misfire is bouncing all over the place. Iput new plugs, wires . fuel filter, fuel pump, change te FPR coils seem to be ok. Ac plugs and wires. also change the intake gasket and still haven't solve the problem. I've have no sign of a blown head gasket. I'm running out of options. The cads doesnt seem to be bad. I've not change the o2 sensor. Cleaned the egr valve Can someone help me with this please?
Old Feb 29, 2012 | 6:56 PM
cleveland63b's Avatar
what do you mean the misfire is bouncing? have you had different codes?
Old Feb 29, 2012 | 7:04 PM
evans906's Avatar
Default Re: Misfire
What is the P code?
Old Feb 29, 2012 | 7:51 PM
jpolk1's Avatar
well it was only showing a misfire on 7 and 8 it and now it has moved to 1,3 and 5. The code just shows a random misfire. It seems to get worse when it gets warmer.
Old Feb 29, 2012 | 7:54 PM
jpolk1's Avatar
I had an egr code but after cleaning it went away. only showing a misfire code
Old Mar 1, 2012 | 4:24 PM
evans906's Avatar
Default Re: Misfire
OK, so your getting a P0300 code (random Misfire) is that correct. And no other codes set, right.
Old Mar 1, 2012 | 4:34 PM
evans906's Avatar
Default Re: Misfire
One other thing, Do you remember what the egr code was? A defective egr valve would leak exhaust gas into the intake manifold. Also a vacuum leak at the intake manifold or throttle body.
Old Mar 2, 2012 | 5:34 AM
jpolk1's Avatar
No I don't remember
Old Mar 2, 2012 | 4:07 PM
evans906's Avatar
Default Re: Misfire
OK, so you cleaned the EGR valve, did you also clean the intake port to the EGR valve?
buddyleno
Mar 31, 2017 8:13 AM
Biggumzmcgee
Nov 15, 2009 10:51 AM
JetSnake
Jul 14, 2009 2:43 PM
akimber
14
Aug 22, 2006 11:45 AM
bmc257
Jul 7, 2006 3:21 AM
