n. its Newbie to the chevy world. help me
Old Jul 30, 2007 | 7:50 PM
shayandude's Avatar
Default n. its Newbie to the chevy world. help me
Hey guys,
I just got a 02 chevy silverado, and top of the roof it has these factory lights
and i cant find how to turn them on
any idea?
thanks in advance
Old Aug 2, 2007 | 3:57 PM
jiggsy's Avatar
Default RE: n. its Newbie to the chevy world. help me
The lights on the roof come on when your park lights come on. Do your park lights work? If they do and
the roof lightsstill don't work, you might want to check the bulbs. If they're good, you'll need totrace your harness to see if you don't have a short in it.
When (if) you get to that part, post again and we'll see what we can do to help.
Old Aug 2, 2007 | 7:29 PM
kcb37's Avatar
Do those lights run on a different fuse?
Old Aug 2, 2007 | 10:04 PM
shayandude's Avatar
hey guys, thanks for the replies,
All my lights come on but those,
hard to imagine every one of them are burnt out.
Im going to check them tomorrow morning and see if that is the problem and ill post as soon as i find out
thanks again,
Shayan
Old Aug 3, 2007 | 3:49 PM
MalibuMaxxSS's Avatar
is it a 3500????,
if not im guessing someone put the lights there for looks and never hooked them up, or they are on a differnet switch somewhere, a 1/2 wont have roof marker lights, and neither will a 2500 only 3500 and bigger are supposed to come with them factory.
Old Aug 3, 2007 | 6:11 PM
ZX1100F1's Avatar
Roof Marker Lamps (Option code U01) were an option on the 2500 and 3500 (non-dually) and standard on the Dually's.
I'm not going to make a guess but I would check the bulbs first.
Old Aug 3, 2007 | 11:15 PM
shayandude's Avatar
mine is the 02 chevy silverado 1500 z71 with the tow package and so on.......
how can i post a pic up?
if you go to facebook.com
and in the search engine put shayan gulzar
it'll come up.
thanks
Old Aug 4, 2007 | 10:36 AM
if its a 1500 then they wont be factory, the option on the 2500 must be a US thing cause you cant in Canada, only the 3500 come standard on duallys and yes option on fleet side
doubt all the bulbs are burnt, be weird, check for a seperate switch, if it were me I would have wired them to my park lights and fused it on a relay somewhre around the battery....check for the fuse, see if its popped.....they may not come on unless you have the truck turned on as well, some people wire them to a non live fuse in your fuse box(only gets power when key is on), so if your parked the marker lights wont be on unless you hve the key on, be more likely if they are on a seperate switch. that way in case you leave the switch on if the key is off the lights wont stay on..
Old Aug 4, 2007 | 11:25 PM
shayandude's Avatar
no, lights arent burnt, no fuses are blown, and no switch anywhere.
would soembody just mount them for looks?
moneyg77
Jan 19, 2014 9:49 PM
CRAIG1983
Nov 12, 2013 7:17 PM
knudles
10
Apr 14, 2010 8:57 PM
Schmidt
Feb 18, 2009 11:30 AM
