Need 12 volt power source
Old Feb 27, 2010 | 6:03 PM
0j0's Avatar
0j0
Default Need 12 volt power source
I have a 2003 Silverado and want to add an accessory plug to the overhead console. Can I plug a connector in the left ip fuse block labeled "BODY - 12 WAY - BRN" for my power? What exactly is that spot meant for?
Old Feb 27, 2010 | 7:50 PM
UH60sSuck's Avatar
I just put interior LED Lights in my truck and i picked up this thing that plugs in to a fuse spot then two fuses plus in to that and it has a accessory wire coming out and I put it ion the ignition one and works great.
Old Feb 27, 2010 | 7:53 PM
maxxman04's Avatar
send me a pic or link to get one. sounds like something i need.
Old Feb 27, 2010 | 8:04 PM
UH60sSuck's Avatar
Here is a Pic dunno exact name. I just went in and explained it to them and they showed me where it was. It was right next to the fuses.....lol if you couldnt og guessed that. thay had them at autozone btw
Old Feb 27, 2010 | 8:15 PM
maxxman04's Avatar
sweet! thanks hoss. that's exactly what i need. been ta dang store quite a bit lookin. maybe i need to open my eyes better. thanks again bro!
Old Feb 27, 2010 | 8:21 PM
UH60sSuck's Avatar
No problem.... I just took a test light and put the keys in and tested them to see which ones would light up. IGN ended up being a good on because there was nothing on one side of it so it wasnt blocking any of the other fuses.
Old Feb 28, 2010 | 12:07 PM
0j0's Avatar
0j0
Thanks, I'll look into that. I never would have thought something like that existed. I have a slot labeled "aux pwr 2" and my owners manual says its not used. Just hope it's not on the battery run-down protection circuit since I want to use this power to charge a cell phone.
Just found it on Amazon.com It's called "add-a-circuit/add on circuit". Now can someone tell me which fuse goes to the original accessory plugs? I'll just use that circuit.
scumpoozie
Jun 10, 2013 7:19 AM
borygoya
Oct 24, 2009 1:10 PM
95bluez71
Aug 22, 2008 6:46 AM
biglg
Jan 28, 2008 8:26 PM
addkev
Nov 19, 2007 9:25 PM
