Tranny Problem
Old Feb 24, 2010 | 11:35 AM
prewitt21's Avatar
Default Tranny Problem
First off I'm new to this site. I recently purchased an 04' Silverado 5.3 Z71 back in in November. It has 113,000 on it now. Just the other day I was driving and noticed rough shifting between 1st and 2nd. Shifting through the other gears is smooth. I checked the fluid level and it looks fine. I'm getting my filter and fluid changed tonight or tomorrow. Anything else that you guys might suggest?
Old Feb 24, 2010 | 12:15 PM
gotstylez's Avatar
my 95 did the same thing.. i got it flushed and it cleared it up in about 25 miles or so driving on it. make sure u get it FLUSHED not just changed.. flushed will get ALL of the fluid out not just what is in the pan..
Old Feb 24, 2010 | 12:29 PM
cam3439's Avatar
Yeah, do the flush. I would also put a trans cooler on there (its a cheap insurance). Your's probably came with one stock, but I would put a better one on there. I have a stock and a B&M next to it as well. Oh, and put synthetic fluid.
Old Feb 24, 2010 | 6:33 PM
prewitt21's Avatar
Alright so a flush and not a change, because some people were saying I shouldnt flush it and that it would cause damage. Anyways I'm going to go ahead and do the flush then. Thanks alot.
Old Feb 24, 2010 | 6:37 PM
gotstylez's Avatar
well a flush just gets all of the old fluid out and it pumps all new fluid in at the same time.. if u do just a change all your doin is getting the fluid from the pan out..there is still fluid in the pumps n all of that in the trans
Old Feb 24, 2010 | 6:41 PM
cam3439's Avatar
The flush only damages the trans if the shop doesn't know what they're doing or if you haven't been taking care of your trans and allowed build-up (which can come loose). I changed mine when I first got my Tahoe (at a little over 100k) and it's been fine since then (now at 170k).
Old Feb 24, 2010 | 6:42 PM
gotstylez's Avatar
also i want to add..they will ask if anything is wrong.. i told 1 place yeah it shifted hard they said they wouldnt touch it...i took it to goodyear and tld them nothign was wrong.. then changed it and it shifts good as can be.. its a 50/50 chance..i think i started a tread about changing tranny fluid..
Old Feb 24, 2010 | 6:51 PM
prewitt21's Avatar
Thanks for all the insight. Yeah i take it to a buddies of mine that has worked on my families vehicles for years. Should be fine. I'll have it flushed and then let you guys know the outcome.
Old Feb 24, 2010 | 6:53 PM
gotstylez's Avatar
sounds like a plan.. i had to drive mine about 25-50 miles mainly around town. and it smoothed it out pretty good.
Old Feb 28, 2010 | 1:09 PM
prewitt21's Avatar
got the flush done. runs smooth now. thanks guys.
A. T
Nov 29, 2011 5:03 PM
DeHartShadow
Mar 28, 2010 10:10 PM
89silverado283
Feb 16, 2010 8:50 AM
revamped
Aug 24, 2008 10:48 PM
revamped
Jan 23, 2008 4:03 PM
