Need help bad, '89 1500
Old Dec 16, 2010 | 4:24 AM
flatbroke's Avatar
Default Need help bad, '89 1500
I hate making my second post be begging for help, but I'm in a spot. Got a truck I need on the road but ain't. Here's the background;
Truck was running fine. Let it set two days in the cold (I'm in Indiana), third day she won't start. Not dead battery, just wouldn't start. She acted like she WANTED to fire, but wouldn't. So far, I've put Heat in the tank, cleaned the rotor and distributor, put in new plugs, sprayed ether into the carb (Or ported fuel injection, can't remember what they call 'em), and cussed a lot. Nothing has worked, and now I have gas in the oil, which I kinda marked up to flooding it.
The only thing left I could think of is that she hasn't had a tune-up since I bought her (hangs head in shame), and thought the cold weather may have made the plug wires brittle and the plugs aren't getting enough fire. I know they're getting SOME, but dunno if it's enough.
Any ideas?
Old Dec 16, 2010 | 9:57 AM
SilveradoShane413's Avatar
Check plugs and maybe have a tune-up if you get her started
Old Dec 16, 2010 | 12:07 PM
DoubleO7's Avatar
Does it fire at all with the starter fluid sprayed in WHILE CRANKING??
(not sprayed in, then go get in cab and turn key)
Old Dec 16, 2010 | 7:35 PM
6LCHEVYZ71's Avatar
First you need to figure out if your truck is missing fuel, spark, or air. Like already mentioned, does it crank for a second when you spray starting fluid into the throttle body? Post up with more info.
Old Dec 18, 2010 | 7:16 PM
flatbroke's Avatar
Yeah, I was cranking it while a buddy sprayed in the either. She TRIES to start, but just won't. I've also now eliminated ignition module. She's spraying fuel through the jets, getting spark, and air.
She's got almost a complete tune-up, and if she started, I wouldn't be having a problem SilveradoShane. lol
Old Dec 18, 2010 | 8:06 PM
DoubleO7's Avatar
Make sure it is actually pumping 100% gas.
Maybe you have too much water in the tank.
Leave all spark plugs out overnight to dry out the cylinders.
Old Dec 19, 2010 | 1:27 AM
2wd-K5's Avatar
water inj the tank may be the cause, all u have to do is touch the fuel coming up the lines, gasoline makes your hand instantly cold, if water is in there...not so much the quick fix is to drain the tank and put new fuel in along with some methyl hydrate
Old Dec 19, 2010 | 6:57 AM
flatbroke's Avatar
Thanks for the idea guys! I want my truck back. I don't mind driving the wife's El Dorado, but I'm just a truck kinda guy.
Chev_Hoe
Jan 14, 2014 9:41 PM
bavant
Jan 16, 2012 2:12 PM
LatitudeDancer
Jun 3, 2011 1:06 PM
mikey613
Apr 13, 2010 6:31 PM
992door
Aug 24, 2009 9:40 AM
