Is it the oil pan leaking?
Old May 23, 2010 | 2:44 PM
tom5170's Avatar
Default Is it the oil pan leaking?
I noticed a wet spot right underneath the truck under the engine. I believe that it is the oil pan. I put my hand on the wet spot, and it was the color and thickness of oil. Are these things hard to replace and can I do it on my own?
I dont have my jack right now and MAYBE luckily since its a Z71 and Z71's suspensions sit a little highter, i might be able to crawl under and have enough room to remove it?
Old May 23, 2010 | 2:46 PM
tom5170's Avatar
My oil cooler lines have been sweating oil at the fitting right where they connect into the radiator. I havent checked where they run to, but it might just be that leaking and not the oil pan?
Old May 23, 2010 | 3:25 PM
tom5170's Avatar
I looked under there again and noticed this other fluid. It was a lighter brown and it smelled like some kind of other chemical... ahh god... I cannot afford to fix all this! what is this?
Old May 23, 2010 | 6:28 PM
72c10gunn's Avatar
If it was trans fluid it should be red/pink it has a distinct smell to it, if it is your trans fluid and its brown then your gunna have some more problems soon
Old May 23, 2010 | 8:17 PM
tom5170's Avatar
the trans fluid on the dipstick is red. maybe its a brake line? is there a brake line by the oil pan? maybe its not the trans and its a brake line?
Casual Mechanic
Jun 22, 2015 11:20 AM
grndslm
Dec 18, 2012 2:38 AM
blkclipse
May 24, 2008 8:15 PM
91z28camaro32
Mar 2, 2006 8:11 PM
paulk
Feb 11, 2006 2:20 AM
