Question about my truck and tires that might fit it. need help immediately!
Old Jan 20, 2010 | 4:08 PM
I Are Hunter's Avatar
Default Question about my truck and tires that might fit it. need help immediately!
I have a 2000 Chevy Silverado 2500 ext. cab 4WD 6.0L V8 Vortec. Im about to buy new tires for it, and the tires I have on it now are 285/75/16's. My question is, will BF Goodrich All terrains 305/70/16's fit my truck? Im asking because there looks like there isn't much clearance between the back tires and some frame part. Please help! Thanks!
Old Jan 20, 2010 | 4:29 PM
nauticstar87's Avatar
I'd be more worried about the front tires rubbing then the back.
Old Jan 20, 2010 | 7:38 PM
well would they rub if I had 305/70/16's?
Old Jan 21, 2010 | 10:18 PM
992door's Avatar
I think you will be fine maybe have to crank the torsion bars alittle. OR you might have to do a little trimming but i dont think it would be much.
Old Jan 21, 2010 | 11:37 PM
what kind of trimming?
Old Jan 23, 2010 | 12:10 PM
992door's Avatar
Maybe just some on the front valance but i am not positive
Old Jan 24, 2010 | 6:14 PM
can anyone else help me any?
Old Jan 24, 2010 | 6:30 PM
I'd suggest trying to run 285s until you get a lift. The back I wouldnt worry bout rubbing unless the truck will be flexing a lot. the front will rub with 305s, you may have to do trimming or crank the torsion bars like 992door said.
Old Jan 25, 2010 | 6:31 PM
what about 295's?
Old Jan 25, 2010 | 10:54 PM
992door's Avatar
295s are taller and wider than the 285's but the 295's are taller than the 305 but the 305 is wider
ohioguy
May 24, 2021 8:26 AM
Mchappie
Feb 11, 2015 10:47 PM
pinkblob66
Apr 5, 2014 8:53 PM
