question!! Please LOOK!! Help!! Anyone?
Old Sep 26, 2009 | 10:43 PM
j0nblazeish's Avatar
Thumbs down question!! Please LOOK!! Help!! Anyone?
I have An 07 silverado Classic...v8 4.8l...regular cab....I Broke My differential.....Can I use A differential And Drive Shaft From a 06 silverado regular cab...4.6L v-6?? Please Help Me find out??
Old Sep 27, 2009 | 6:10 AM
nauticstar87's Avatar
not sure bout the driveshaft. I would assume if the transmission is the same than yes. For the rear-end, If you have a 2wd, then yes. if the gears are different, between the 2 rear axles, you'll have to reprogram your computer.
Old Sep 27, 2009 | 1:43 PM
Default Update....Please Read
Okay The Broken differencial Is the 07 Silverado regular cab v-8 4.8L automatic....My buddy has parts from a 06 Silverado regular cab..v-6 4.6L 5 speed....Would the Differencials and driveshafts be interchangeable??? please help
Old Sep 27, 2009 | 2:11 PM
therewolf's Avatar
Look in the glove boxes at the ROP codes for the rears. Should be "gt5"(410s),"gt4"(373s) etc.
What the hell is a "regular cab"? Do you mean 2WD? Or 1500 or what?
Bear in mind, if it's a 4WD, the front diff and the rear diff ratios MUST be the same.
Old Sep 27, 2009 | 3:37 PM
Default Differencials...
Both Are 2wd....
Old Sep 27, 2009 | 7:22 PM
bad2006z71's Avatar
a regular cab is a non extended and non crewcab truck that can either be a 6' or 8' bed
Old Sep 28, 2009 | 12:02 AM
Question how about??
would the rear suspension be interchangeable as well???
Old Sep 28, 2009 | 12:12 AM
Speedy650's Avatar
pictures of both trucks maybe?
Old Sep 28, 2009 | 10:23 AM
therewolf's Avatar
Need more real info here, likely you do have a matchup, but we're flying blind until you provide more specifics.
Matt_pound
May 22, 2013 7:45 PM
Dirtiest Hoe I know
Dec 1, 2011 7:45 PM
decepts
Apr 1, 2010 11:47 PM
IROCZ5.7LITER
Camaro
Feb 10, 2010 7:24 PM
rob1208lv
Jan 24, 2007 6:56 PM
