Re: 2001 1500 5.3 vortec stalling
Old Mar 16, 2007 | 11:09 PM
opie4487's Avatar
Default Re: 2001 1500 5.3 vortec stalling
I got a 2001 silverado extended cab w/ a 5.3 Vortec in it....every once in a while when I pull up to a stop sign or traffic light, then engine will cut off. It always starts right back up and will run fine...I replaced the fuel filter and checked the plugs...It is not a severe problem at the time, but it is a bit of an anoyance...Thank you
Old Mar 17, 2007 | 3:53 AM
sm3earl's Avatar
Default RE: Re: 2001 1500 5.3 vortec stalling
maybe a vaccume leak, a big one? That happened to me when i was working on a 84 chrysler v8.
Old Mar 17, 2007 | 6:26 PM
ZX1100F1's Avatar
Unplug the vacuum hose going into the fuel pressure regulator on the top driver side fuel-rail, if gasoline drips from the end of the hose then the fuel pressure regulator is faulty and should be changed.
9 times out of 10 this is the cause for stalling such as you describe.
Old Mar 17, 2007 | 10:57 PM
opie4487's Avatar
I unplugged the the hose w/ both the engine off and the engine running....there is a good vaccum on the hose and no fuel leaked either time....
Old Mar 18, 2007 | 2:03 AM
Check fuel pressure. Could be a fuel pump going south. Or TU.
Old Mar 18, 2007 | 12:33 PM
ZX1100F1's Avatar
Cody,
How many miles are on your truck?
Old Mar 18, 2007 | 12:49 PM
opie4487's Avatar
I will check the fuel pressure...the truck has 145,000 on it...It hasnt really stalled again in the past couple of days, but i'm sure I havnt fixed the problem
Old Mar 19, 2007 | 7:37 PM
ZX1100F1's Avatar
With that many miles you may want to try going to Costco or Sam Club and purchasing a 4-pack of Chevron Fuel Injector Cleaner (16oz bottles) with Techron for $9.95
Go to the gas pump and add all 4 bottles to your fuel tank then top it off with gas and drive it till it is near empty before you refuel.
Old Mar 19, 2007 | 8:45 PM
opie4487's Avatar
I will try it...it seems to be doing a little better...It hesitated only one time in a couple days....Thanks, I'll let you know what happens
jaxontipedeau
Feb 6, 2011 11:48 AM
lwg660
Nov 28, 2009 11:34 AM
rotax_rave
Sep 28, 2008 11:12 AM
twstr988
Jan 24, 2008 2:12 PM
yellow73bb
Jul 6, 2007 3:58 PM
