Red or green antifreeze?
Old Oct 17, 2013 | 7:46 AM
white03's Avatar
Default Red or green antifreeze?
Gonna do a coolant flush on a 2003 chevy, I heard that I should put green back in instead of the red?
Old Oct 17, 2013 | 8:47 PM
country_09's Avatar
Pretty sure it should be dex cool orange. Whatever you don't mix green and orange together. It likes to clump together when mixed
Old Oct 18, 2013 | 3:06 AM
iluvchevy's Avatar
You can flush out the red and replace it with green. From what I've heard, green is better for the gaskets.
Old Oct 18, 2013 | 10:51 AM
Fishinfooleric10@aol.com's Avatar
Yeah they say you are supposed to use the dex-cool coolant because it will keep the aluminum heads from corroding; however, I believe this to be crock of bull. Like country said don't mix them but put either one in there, you will be okay.
Old Oct 18, 2013 | 4:43 PM
As I understand it the advantages of Dexcool are: its ability to do better with aluminum, its less harsh on seals and gaskets, it last much longer then standard antifreeze... dexcool will go the full 100k miles and 5 years of your warranty without servicing...
Old Oct 18, 2013 | 4:47 PM
I also heard that Dex Cool is more friendly to the environment.
Old Oct 18, 2013 | 5:12 PM
campingfriends's Avatar
Angry anti freeze
whatever you do, do not allow pets to have access to anti freeze, it is extremely toxic.
Old Oct 18, 2013 | 8:50 PM
JK23112's Avatar
I bought my 2004 Silverado used in 2010. It had the DexCool (orange) coolant in it, so when I had it flushed, I had them use the same stuff. Also, it is what is recommended by GM.
In my other vehicle, a Nissan Sentra, I use the green Prestone stuff.
Old Oct 22, 2013 | 2:43 AM
Earth Rider's Avatar
IMO, As long as truck is out of warranty I would consider "green" antifreeze. I had issues with intake gasket failure on a 99 5.7 li Vin R that I really believe was a result of using the orange antifreeze. I suspect the orange stuff degraded and attacked the gasket material causing it to fail. Failed gasket was like a "wet noodle" at the point where it failed. Could have been the gasket but I felt better using the green stuff because I never had trouble with it before. Had to replace a leaky water pump early too.
Changed to green antifreeze about a year ago and have not had any issues with it.
Whether using either green or orange it should be serviced according to recommended schedule or a little earlier.
Old Oct 22, 2013 | 4:32 AM
Kiss4aFrog's Avatar
What he said. Biggest thing is to change it out when it's due. I use a little added insurance and every other year add a can of "anti-rust' or in the old days "Water pump lube"
You don't want to mix dex-cool with anything. I wouldn't even take a chance with the new formulas that say mixes with anything.
Dex-cool will form a gel if you mix it with the regular green stuff. Worked on a couple gelled ones and it's a pain to get them open again. Same if you make the mistake of adding Dex to regular. Either way it's a bad scene.
IMHO Out of warranty, I'd go with a standard non Dex long life coolant.
Attached Thumbnails Red or green antifreeze?-cooling-system-anti-rust-prestone.jpg   Red or green antifreeze?-antifreeze-peak.jpg   Red or green antifreeze?-antifreeze-prestone.jpg   Red or green antifreeze?-antifreeze-walmart.jpg
chris2014
Aug 28, 2014 5:20 PM
mountainlady
Sep 18, 2011 8:00 PM
rabbit0102030
Apr 7, 2007 4:16 PM
01TahoeLS
Nov 29, 2006 8:49 PM
