Seriously disappointed
Old Oct 2, 2020 | 6:19 PM
rcorn1031's Avatar
Banned
Default Seriously disappointed
Own an 2007 Silverado 1500 with active service stabilitrak light and airbag lights active again .
Really am disappointed in GM for not offering parts support for KNOWN ISSUES with failed “Genuine GM PARTS “ for Steering angle sensor issues in stabilitrak systems and front impact sensors in airbag restraint systems .
I have replaced both front impact sensors before to clear the airbag light .
I am not looking forward to changing the steering angle sensor on the steering column primarily because GM does NOT OFFER a 6 pin sensor for direct replacement .
I was able to locate an 8 pin sensor that is by others accounts supposed to fit and function properly .
When are the geniuses in Detroit going to realize that not all drivers or owners have a need to replace a vehicle “Just because” it is older than the legally mandated support period of 7 YEARS.
Case in point mine is 13 years old and still worth keeping around as opposed to the astronomical cost of New or recently used .
All we want is a little owner loyalty in the form of available parts for our vehicles because aftermarkets are lacking in quality and longevity / durability of product .
So how does one make an 8 pin sensor work where a 6 pin sensor was originally specified ??
Anybody ???
Updated status on issue . May 2 2021
Problems solved . Steering angle sensor was Not the issue . Steering column ended up 360 degrees off center when intermediate shaft c-v boots were replaced .
Air bag light was caused by data-bus error to the main body control module . There were 2 fuses in the engine bay fuse panel that were corroded clear thru and failed continuity check .
after disconnecting negative battery cable .
ALL fuses and relay connections were tested and had corrosion preventative grease applied to the sockets and terminals
Product used is “Truk-lite YK77” 2 fuses were replaced . The airbag light turns off after self test and passenger seat now shows when it is occupied .
Old Oct 2, 2020 | 7:18 PM
post a pic of the sensors. are the connectors the same but the six pin has 2 blank pin chambers? What years is the 8 pin from?
don't buy a ford...they drop parts much sooner than any other manufacturer.
Old Oct 2, 2020 | 7:29 PM
rcorn1031's Avatar
Banned
Default sensors
I have not disassembled my truck yet .
I also have no pics other than what i have seen online .
I have received a new 19418403 sensor today
It has 8 pins in an 8 pin cavity and is listed to fit ‘13 cadillac escalade steering column
and the reference to the original 15886733 sensor is 6 pins in an 8 pin cavity as well as 6 leads in an 8 pin connector
dgoode1
Feb 24, 2018 9:16 AM
Typerod
Sep 15, 2016 1:44 PM
buttanic
Nov 24, 2015 10:48 AM
lowflyer
Sep 29, 2012 9:45 AM
lorennmeg
Oct 12, 2008 1:11 PM
