Silverado Loss of power??????
Old Sep 22, 2008 | 4:09 PM
34dodge's Avatar
Default Silverado Loss of power??????
I also have a 2004 silverado 5.3 64,000 miles with 20' rims and tires. i am having some of the same problems as another member. Sometimes when i mash the gas the truck takes off...not as much as it used to but it goes....then some times i feel i could walk faster than the damn thing its almost embarrassing...can anyone help?
Old Sep 22, 2008 | 4:13 PM
34dodge's Avatar
Default RE: Silverado Loss of power??????
one of my buddies told me possible fuel pump...or fuel filter??? i want my power back!!!!
Old Sep 22, 2008 | 5:10 PM
Deteoni's Avatar
He could be right. Replace the fuel filter first since that's the easiest and cheapest to do.
It could be partially clogged. Good luck.
Old Sep 23, 2008 | 7:49 AM
jackyshaikh's Avatar
If that does't help,perform engine tune-up and check exhaust back pressure test as well.
Old Sep 23, 2008 | 10:15 AM
Deteoni's Avatar
Other things to check isthevolume and pressure from the fuel pump/Fuel pressure regulator/Injectors/even a gas cap can give you problems.
Old Sep 24, 2008 | 8:10 PM
Fire123's Avatar
My 2007 seems to do the same thing. Only 24,000 miles on it. Going to have the dealer check it when I have them do some other work.
Old Sep 24, 2008 | 10:41 PM
6970pickup's Avatar
I am not usre if that model has EGR valve, but they can bind and then work . If its open power goes west.
Old Sep 29, 2008 | 4:58 AM
Skilogenimeno's Avatar
maybe clogged injectors also
Korin420
Apr 26, 2013 6:53 PM
matthewoneil10
Aug 13, 2011 1:03 PM
flmeyebrows
Jun 21, 2011 10:51 AM
lennonjunior
Jul 14, 2009 10:31 AM
jlbeir
Nov 21, 2008 4:11 PM
