Smoking Brake
Old Jan 20, 2011 | 3:08 PM
ONLYNAMRICA's Avatar
Default Smoking Brake
Just serviced brakes, new rotors & pads on all 4 corners, bleed brake system which was like syrup. Took it for a test ride, every thing seemed ok. Next day wife calls me and she advises that the drivers rear brake is smoking and very hot. 2001 1500 silverado, any help would be great, Thanks in advance
Old Jan 20, 2011 | 3:37 PM
RacerX's Avatar
Did she leave the emergency brake on?
Old Jan 20, 2011 | 3:43 PM
parking brake is on, or its mis-adjusted and dragging, the piston has over extended and stuck out, pads are misaligned...
basically you'll need to take it apart to find out for sure....
Old Jan 20, 2011 | 3:53 PM
RacerX's Avatar
I dont think the piston is overextended. Because if he put in NEW pads the caliper wouldnt go back on the mounting bracket if the piston was extended. Same with the pads, I dont think the hold down bolts would go back in smoothly. But in any event you will have to disassemble that wheel to see if your wife had left the brake on or if you did the job wrong.
I bet she left the E-brake on.
Old Jan 21, 2011 | 7:33 AM
ExcessiveEgo's Avatar
or he got brake fluid on the pads when he bled the brakes
Old Jan 22, 2011 | 5:35 AM
Update--checked caliper and pads, nothing wrong with assembly, it's when the brakes are applied they don't release and it's occuring on both rear wheels, I suspect that the master cylinder is the problem? Thank you for all coments, the little stuff will hurt you however I didn't let brake fluid get on the pads, the emg. brake isn't the issue---the brakes won't release after application-----
Old Jan 22, 2011 | 7:54 PM
RacerX's Avatar
Sounds like sticking in the master cylinder. Replace they are cheap enough.
Old Jan 25, 2011 | 11:35 AM
UP-DATE; Changed out the master cylinder, checked out brakes-----SAME THING----THEY WERE STILL STICKING!!!! OK NOW!!! So now there's only 2 items left to change----the calipers or the ABS or BOTH---well the cheap person I am I opted for the calipers 1st, $32.00 apiece and $30.00 apiece core charge!!! Replaced them both----FINALY WORKS!!!!!! Guess that happens when brake fluid is like syrup!!!!! Thanks to all who tried to help------
Old Jan 25, 2011 | 11:32 PM
RacerX's Avatar
somebody did somebody wrong song. Brake fluid shouldnt be syrupy even when its old. Unless someone put another fluid in there...like ATF or clear power steering fluid.
blackedout
Nov 24, 2013 3:07 PM
jacob brooks
Feb 3, 2010 2:30 AM
SuperTexan
Jun 13, 2009 12:41 AM
kobiewhite
Feb 23, 2009 2:26 AM
sage0501
Mar 29, 2008 12:38 PM
