Stuck on defrost 04 Silverado
I know. I know. You are probably thinking to yourself, "here is another stuck on defrost thread." You are right and wrong. Yes my hvac is stuck on defrost and no because I have searched and completed everything I have read from pulling the fuse under the hood to disconnecting the battery to holding the ac button while turning the selection ****. Everything I read I tried but still to no avail. It started while I was on deployment and my wife left the xm radio on and killed the battery. The odd part is that if I pull the HVAC fuse under the hood the air blows through the vents but of course no ac or selection. So I know the wiring and hardware is good. Maybe I just didn't find the right procedure to reset the computer. Any help would be appreciated.
well after disconnecting fuse/battery and still not working, then i would check for a bad blend motor.. sorry to say there not cheep. common on some of 02+
sorry i can't be more help..
good luck
good luck
BigblackHo3
Apr 5, 2013 8:54 AM
EagleEye82
Feb 21, 2012 3:02 PM
mummp
Oct 13, 2009 8:48 PM
