switched positive???
Old Sep 4, 2013 | 1:41 PM
vwfye's Avatar
Default switched positive???
I'm trying to locate a source under the dash of my 89 1500 a place to access 12v switched power. I haven't had a chance to under the dash and look yet. Since I don't have power anything in the truck, are there several switched sources open in one of the panels down there? I assume if since this is a GM product that there is a fuse panel and an aux panel down there. Is this a correct assumption?
Thanks for any help, from one electrical novice!
Old Sep 4, 2013 | 10:14 PM
The radio, turn signals and A/C are switched. What do you plan to hook up to it? You can tie into these lines if you don't overload the fuse.
Old Sep 5, 2013 | 5:05 PM
vwfye's Avatar
I'm just looking to ad a little 2" tach for when I haul my trailer to see how hard the engine is working. I have a panel under the dash that has many wht red grn markings with open spades, but I don't know what they would be for or if the only ones that will have + are the ones marked red.
Old Sep 6, 2013 | 11:13 AM
Check them with a voltmeter to see which ones are controlled by the ignition switch. When you do hook up the tach, remember to put a fuse in the line unless those spades are already fused.
bommer
Apr 3, 2011 5:29 AM
slider_buck
Dec 7, 2010 2:42 PM
guvner
Jul 11, 2010 9:36 PM
cheshirew
Apr 1, 2009 1:45 PM
brown_fern
Oct 19, 2007 11:36 PM
